Prépa ANDY FORREST
Prépa ANDY FORREST
Message non lupar bluewrx » Ven 11 Avr 2008 01:14
Les prépas vu par ANDY FORREST :
http://www.andyforrestperformance.co.uk/4436.html
Le Bleu c'est beau ...
RD Performance Team
bluewrx
En ligne: 19h 23m
Re: Prépa ANDY FORREST
01-05 WRX 2.0 UK/EURO STD 218/225 BHP
Level 1 260-280 bhp
Full Decat or Sportscat exhaust from turbo back 2.5 or 3” bore
Ecutek Custom ECU recalibration (similar to PPP)
Twin boost set up for high/low power switchable in-car
Walbro 255 l/hr uprated fuel pump
K+N panel filter
Level 2 290-310 bhp
Full Decat or Sportscat exhaust from turbo back 2.5 or 3” bore.
Decat uppipe Pre turbo
K+N panel filter
AFP 04-H custom ported hybrid turbo
High Flow multi spray fuel injectors 550cc (380cc as std)
Uprated turbo to intercooler 'Y' pipe
NGK PFR 7B uprated spark plugs
Level 2(a) 300-320 bhp
Substitute VF34/35 or TD05-16G turbo in place of AFP04H for additional 10-20bhp but with slightly later turbo spool up.
Level 3 360-390 bhp
Full Decat turbo back 3” bore exhaust system
Tubular exhaust headers and flow matched uppipe
K+N panel filter
EcuTek custom ECU calibration.
550cc Multi Spray Injectors
Fuel Lab turbo specification fuel pressure regulator with fitting kit & gauge
STI TMIC from 01-06 STI including undertray
AFP 05-20G custom ported turbocharger modified to fit with TGV
Level 3 Power may shorten the life of the transmission system this will depend on use and driving style. The 01 onwards UK 5 speeds do currently seem to be coping well with this level of output although as mileage increases this may become more of an issue.
Level 4 390-410 bhp
STI TMIC from 01-07 STI including undertray
AFP 321H custom turbocharger with fitting kit
Twin port 650cc Injectors
Custom cold air induction system
Level 5 420-450 bhp
STI TMIC from 01-07 STI including undertray or optional FMIC
AFP 321T custom turbocharger with fitting kit
AVCR boost controller
NGK racing 8 spark plugs
Note We do not recommended level 4-5 on standard internals, clutch or gearbox. As a mimium we recommend forged pistons
and steel rods, steel head gaskets, uprated clutch. We also recommend either a PPG gear kit or 6 speed gearbox conversion ( from later STI)
RD Performance Team
bluewrx
En ligne: 19h 23m
06-07 WRX UK/EURO 2.5 Std 227 bhp
Level 1 260-280 bhp
Ecutek custom remap
K&N panel filter
Level 1A 290-310 bhp
Add - AFP 04H custom ported hybrid turbo to level 1
Level 2 330-350 bhp
Full Decat exhaust from turbo back 2.5 or 3” bore
Ecutek custom remap
K&N panel filter
VF34 Turbo with ported exhaust & wastegate sized to suit 2.5
NGK uprated spark plugs
Level 3 360-390 bhp
K+N panel filter
Ecutek custom remap
AFP 5-20G Ported Exhaust & wastegate sized to 2.5 and machined to suit TGV
STI 06-07 TMIC
Level 4 400-420 bhp
EcuTek custom remap
Custom Cold air induction
650cc Injectors
Level 5 420-460 bhp
EcuTek custom remap
650cc Injectors
Optional FMIC
Uprated clutch
On 06/07 WRX/STI 2.5 the pistons run very tight bore clearances. On Level 4 and above we recommend a forged piston upgrade. The forged piston upgrade is also recommended for level 3 if used for sustained high speeds or if used regularly on track. Level 5 we also recommend steel conrods, ARP head studs and uprated head gaskets.
RD Performance Team
bluewrx
En ligne: 19h 23m
Message non lupar bluewrx » Ven 11 Avr 2008 01:15
01-05 STI 2.0 UK/EURO + 01/02 JDM STI /RA STD 265 BHP
Level 1 300-330 bhp
K+N panel filter
Ecutek custom remap
Level 2 310-340 bhp
Full Decat turbo back 2.5 " or 3” bore
K+N panel filter
Ecutek custom remap
Level 3 360-390 bhp
K+N panel filter
Ecutek custom remap
AFP 05-20G custom turbo charger modified to fit with tgv delete
Level 4 390-410 bhp
Ecutek custom remap
Level 5 420-460 bhp
Ecutek custom remap
FMIC (Optional)
Note For Level 5 we would recommend uprated steel rods & forged pistons and an uprated clutch.
RD Performance Team
bluewrx
En ligne: 19h 23m
06-07 STI UK/EURO 2.5 STD 265 BHP
Level 1 290-300 bhp
Sportscat Exhaust System
EcuTek custom remap (compares to PPP)
Level 2 340-360 bhp
EcuTek custom remap
K+N panel filter
Level 3 360-390 bhp
K+N panel filter
Ecutek custom remap
Level 4 400-420 bhp
EcuTek custom remap
650cc Injectors
Level 5 420-460 bhp
EcuTek custom remap
650cc Injectors
Optional FMIC
Uprated clutch
Note On 06/07 WRX/STI 2.5 short engines the pistons run very tight bore clearances. On Level 4 and above we recommend a forged piston upgrade. The forged piston upgrade is also recommended for level 3 upgrages if used for sustained high speeds or if used regularly on track.
RD Performance Team
bluewrx
En ligne: 19h 23m
Message non lupar Boomer2-6 » Ven 11 Avr 2008 01:23
manque plus que les tarif ,
par contre ecutek............ :P
piece perf , preparation et remap : http://www.seb-performance.fr
Boomer2-6
En ligne: 5h 6m 22s
Ma voiture: wrxi
Couleur: stroumf
Message non lupar Maxibug » Ven 11 Avr 2008 01:27
interessant déjà le level 3 !
En ligne: 513d 19h 53m 13s
Message non lupar Doclol » Sam 12 Avr 2008 07:50
sebaru a écrit:manque plus que les tarif ,
Je serai curieux de connaitre les tarots ... Bluuuuuuuuuuuuuuuuuue ! :hello:
Doclol
En ligne: 42d 14h 5m 5s
Ma voiture: Gazouz qui pue !
Message non lupar Tosman » Sam 12 Avr 2008 09:48
oui combien ça coûte???
WRX BIOPOWER!!!
Tosman
En ligne: 4d 23h 31m 6s
Ma voiture: impreza WRX
Message non lupar Max62 » Sam 12 Avr 2008 09:57
Comme je ne comprend pas trop l'anglais , pour les wrx 2.5L à partir de 300 cv il ne change pas la boite ou il ne la renforce pas???? 8| 8|
En mode sans sub.......
Max62
En ligne: 94d 3h 57m 44s
Ma voiture: 207 WRC
Couleur: VERT
Message non lupar subifredo » Sam 12 Avr 2008 12:12
Max62 a écrit:Comme je ne comprend pas trop l'anglais , pour les wrx 2.5L à partir de 300 cv il ne change pas la boite ou il ne la renforce pas???? 8| 8|
ben en anglais, boite de vitesse= gear box ;)
et dans les prepa donné, je n ai pas vu que l on parlais de changement ou de renforcement de la boite( corriger moi si erreur :) )
pour le renforcement, les pignons de boite vont aller sur la lune je pense ::d
et pour le changement de boite, meme si la boite 2.5 a ete renforcé par rapport a la 2L, apres le stage 1a, je pense qu il vaut mieux la changer :)
BIENTOT MEMBRE DU 300+
RD PERFORMANCE TEAM DIRECTOR
subifredo
En ligne: 0s
Message non lupar Tosman » Sam 12 Avr 2008 12:40
Pas mieux... je suis étonné que dans aucun cas il se préoccupe des boites! Je pense qu'il veut fideliser le client... ::d
mais il est sympa, il prévient tout de même! :mrgreen:
WRX BIOPOWER!!!
Tosman
Message non lupar Damien » Sam 12 Avr 2008 15:36
"Level 3 Power may shorten the life of the transmission system this will depend on use and driving style. The 01 onwards UK 5 speeds do currently seem to be coping well with this level of output although as mileage increases this may become more of an issue."
"Note We do not recommended level 4-5 on standard internals, clutch or gearbox (...) We also recommend either a PPG gear kit or 6 speed gearbox conversion ( from later STI)"
Faut apprendre à lire les copains... ils n'en parlent que pour les WRX 2L, mais je peux vous dire d'expérience que ce sont les seules à avoir des BDV fragiles, les WRX 2.5 encaissent très bien!
Damien
En ligne: 5d 18h 1m 38s
Message non lupar bluewrx » Sam 12 Avr 2008 18:09
oui et c'est surtout le couple qui faudrait voir ...
les WRX01-05 ca tient 320cv 40-42 de couple
les WRX06-07 c'est plutot 350cv 50 de couple
Damien tu confirmes ?
RD Performance Team
bluewrx
En ligne: 19h 23m
Message non lupar Wattman » Sam 12 Avr 2008 21:16
Ok avec Damien, c'est précisé en bas de page. Pour les boîtes de WRX, je dirais que pour 50mkg, même avec les WRX 2.5 je pense qu'il ne faut pas être trop bourrin avec quand même...
En ligne: 1304d 23h 9m 35s
Message non lupar subifredo » Sam 12 Avr 2008 23:09
il est quand meme sympa de preciser que c est selon la facon de conduire.....y se mouille pas trop la :pascontent2:
:super: merci damien :)
subifredo
En ligne: 0s
Message non lupar toto 78600 » Sam 12 Avr 2008 23:11
sa doit faire mal niveau tarifs
ImageImage[/URL]Image
toto 78600
En ligne: 13h 33m 27s
Ma voiture: wrx limitéé n°225
